Activity Forums Adobe After Effects Any ideas on Zig Zag Path Taper/Warp?
  • Any ideas on Zig Zag Path Taper/Warp?
    Posted by Max Hamworth on July 15, 2015 at 5:58 pm
    I drew this in illustrator by hand (Please see attached image). The Zig Zag feature in illustrator is linear.
    is there a way to taper it or warp it in/outwards?
    Max Hamworth replied 11 years, 2 months ago 2 Members · 2 Replies
  • Kalleheikki Kannisto
    July 15, 2015 at 6:48 pm
    Hi Max,
    (In Illustrator) with path selected, Object>Envelope Distort>Make with Mesh, set columns and rows to 1. This will give you a single-square distortion area with bezier handles that you can use to warp it in or out.
  • Max Hamworth
    July 15, 2015 at 7:39 pm
    Interesting! It was close, but no cigar. Had to modify the end path a little, this way takes me about the same amount of time to draw it manually. :/
