Activity Forums Apple Final Cut Pro Legacy Any ideas on how to make this work?
  • Any ideas on how to make this work?
    Posted by Chrisyocum on September 4, 2005 at 4:49 pm
    Any ideas out there as to how to desaturate all of the colors in footage, thereby making it black and white, while leaving one particular color, such as red, shining through? Like in Schindler’s List and Pleasantville. I have a scene where I want to black and white everything except a couple of strawberries in the foreground. Any ideas would be great thanks. I’m using FCP HD and have motion at my disposal. Thanks.
    Kevin Monahan replied 21 years ago 4 Members · 4 Replies
  • Mike Johnson
    September 4, 2005 at 5:08 pm
    well depends on how the footage looks, but is it possible to work with layers?
    As in duplicating the clip, make it black and white, use the color clip over and add a mask around everything but the strawberrys and make that transparent.
    You can easily do that with motion, but it might be time consuming if you got a long clip.
    Well, it’s how accurate you make the mask that’s consuming.
  • Don Greening
    September 4, 2005 at 5:25 pm
    chrisyocum,
    What you’re describing is sometimes referred to as the “Pleasantville” effect. Here’s a link on how to do it:
    https://www.kenstone.net/fcp_homepage/basic_pleasantville_look.html
    – Don
  • Chrisyocum
    September 4, 2005 at 8:08 pm
    Great link. Thanks so much.
  • Kevin Monahan
    September 5, 2005 at 10:54 pm
    Got this trick in my book as well. Comes with practice footage and step by step instructions.
    Kevin Monahan
    Author – Motion Graphics and Effects in Final Cut Pro
    fcpworld.com
