Activity › Forums › Adobe After Effects › Any ideas on how this was done?
Posted by Chuck Pullen on August 19, 2011 at 2:06 pmWGN in Chicago has been running this new promo, and I really love the look. Anyone have any ideas on how it is done?
https://gizmodo.com/5830648/seeing-chicago-like-this-makes-me-want-to-go-even-more
Chuck Pullen
Walter Soyka replied 15 years ago 2 Members · 4 Replies -
Walter Soyka
August 19, 2011 at 3:55 pmThis is a tilt-shift timelapse shoot. It can be done in-camera with a tilt-shift lens, or it can be faked in post-production by selectively blurring the top and bottom of the frame.
https://en.wikipedia.org/wiki/Tilt-shift_photography
If you have full-motion video, it’s probably best to posterize the frame rate first to get the timelapse effect, which I think is a hugely underestimated component of fake miniaturization.
Walter Soyka
Creative Cow Forum Host: Live & Stage Events -
Walter Soyka
August 19, 2011 at 4:00 pmI should add that Red Giant Software’s Magic Bullet Looks has a “Swing Tilt Film” preset.
Walter Soyka
Chuck Pullen
August 19, 2011 at 4:16 pmThanks Walter, I had an idea in mind, and it would include some stock footage, so everything would probably start as full motion HD video. Besides the Magic Bullet plug-in, what would the frame rate manipulation be?
From what I’ve read it’s similar to a combination of a pull-down and dropping frames. (Change 30 frame to 20 and drop every third frame for example?) It sounds like there may be a setting for that in AE?
Chuck
Walter Soyka
August 19, 2011 at 4:19 pmIn AE, you can use the Posterize time effect [link], or you can precomp your 29.97 footage, change the frame rate of the comp (to perhaps 10 fps), and then check the “Preserve frame rate when nested” box in the comp’s advanced settings.
Walter Soyka
