Activity › Forums › Adobe After Effects › Any idea how can i make this effect?
  • Any idea how can i make this effect?
    Posted by Anastasia Solomou on April 19, 2015 at 3:00 pm
    Hello CreativeCow ppl,
    do you have any idea how can i make this effect from 1:44 to 1:52?
    https://vimeo.com/114129481
    Can you please suggest me a good tutorial for this effect?
    Thank you in advance!
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
    Anastasia Solomou replied 11 years, 5 months ago 2 Members · 2 Replies
  • Tudor “ted” jelescu
    April 21, 2015 at 3:04 pm
    In your example I am quite certain that they used practical effects (a bunch of paper planes suspended from the ceiling with fishing line). However, you could use a particle system like Trapcode Particular, Trapcode Form or even ShapeShifter AE with the Generator to create the same illusion. You will need to freeze your particles (set them up to custom and use the object/image of the object), track the Camera movement and create a 3d camera that matches it and then composite the whole thing in the shot matching the lights, color and depth. You may need to do some roto work depending on your particular shot in order to mask out some objects/people that are supposed to be in front or behind the objects created with your Particle Generator.
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Anastasia Solomou
    April 22, 2015 at 5:36 pm
    Very inside information, thank you Ted
