Activity › Forums › Blackmagic Design › Any gotchas on new system?…
  • Any gotchas on new system?…
    Posted by Jimmy Brunger on June 22, 2007 at 1:13 pm
    Hi all,
    Hoping to upgrade to a new interim system in the next couple of weeks that I hope to run for a few months until we go HD…
    Wondered if anyone knew of any glaring problems I might face using it mainly as an AE workstation (some Premiere/Audition/PS/Combustion work too)
    Stuff like PCI blackhole issues, hardware conflicts, software/hardware conflicts – plugins problems, etc? Cheers in advance guys: –
    Windows XP Pro 32 (SP2)
    Adobe Production Studio Premium (CS2 apps)
    additional AE7 plugs: Knoll LF Pro 2.5 / trapcode suite / Zaxwerks)
    Nucleo Pro
    Combustion v3
    1x AMD Athlon X2 Dual 4200+
    ASUS a8N-SLi motherboard
    4GB RAM (DDR 400 dual channel)
    nVidia 7900GS gpu (GDDR3 256mb)
    Decklink Pro (Short PCI 66MHz)
    110GB (boot/apps) / 80GB (media)/ 600GB RAID 0 drives (footage)
    My current config is in my sig below for reference.
    Any advice very welcome.
    Cheers,
    Jim.
    *Production Studio Premium / *Combustion 3
    Win XP Pro SP2 / Intel P4 3GHz / 2GB RAM / GeForce FX5200 / DeckLink Pro / Sony BVM-20G1E / DVS SDI Clipstation / 110GB boot/80GB media/600GB RAID-0
    Deleted User replied 19 years, 3 months ago 3 Members · 6 Replies
  • Deleted User
    June 24, 2007 at 12:10 am
    Hello Jim,
    I have a similar setup to your proposed HD edit suite please see my profile on here for my breakdown. I have not experienced any problems running After Effects, Premiere Pro, Encore, Photoshop etc.
    I am not sure the motherboard will run properly with 4gb of ram. I currently have 2x1gb memory modules I am looking at upgrading it to 4gb of ram but I was told the baord will have various stability issues as it will not run as desired. Although I have not tested this so I can not be sure of the problems yet.
    I am very impressed as it is a fast enough system for most work.
    Hope that helps?
    Leo
  • Jimmy Brunger
    June 26, 2007 at 10:21 am
    Hi Leo,
    This isn’t the HD system…there’s no way it’d be fast enough for uncompressed HD! I’m hoping for an 8-core Xeon system with tonnes of RAM running XP64 for that. I’m just trying to speed up my uncompressed SD system at the mo, until we go fully HD..
    I’ve heard from a few guys on the AE forum that 4GB should run fine. If the moboard has PCI Express, that eats up a bit of RAM, but there will still be enough left over to make my multiple apps workflow run better. I know BMD say 3GB is the limit for the Decklink, but I *think* that just means it won’t use any more than that, as oppossed to not running properly..
    ..IF someone from BMD would ever read this forum we might get an answer!!!
    Leo – your sig didn’t show up – can you post your specs again? I’m intrigued how you’re running HD efficiently..is it HDV?
  • Deleted User
    June 26, 2007 at 10:58 am
    Hello,
    The Asus I have will do Uncompressed hd playback with the fast supported storage such as Caldigit with I am in the process of looking into buying soon.
    My system specs are
    Motherboard: Asus A8N32-SLI DELUXE
    Graphics: ASUS Nvidia Extreme N6600GT PCI-E 128mb ddr3
    Processor: AMD 4400+ X2
    OS: Windows XP Pro with Service Pack 2
    Memory: 2x1gb Corsair Memory
    Capture Card:
    Firewire Card – On board Motherboard add on
    Decklink Multibridge Extreme PCI-E
    4x250GB SATA 1 drives (RAID 0) for storage.
    At the moment using it for uncompressed 10 bit 4:2:2 sd projects but it is more then capable I was told to deal with hd.
    Quadcore sounds interesting, I am not sure on the 3gb limit of the Decklinks, as I am not sure what problems would be expected. Maybe the hardware does not work??
    Leo
  • Mike Procunier
    June 26, 2007 at 2:24 pm
    That 3GB limit is for real. I’m not sure how it affects PC’s, but on Intel Macs it locks up the entire machine without fail EVERY time you I bring a new clip onto the FCP timeline. I’d email BM directly and ask them how it will effect your system. The 3GB limit is a NIGHTMARE.
  • Jimmy Brunger
    June 27, 2007 at 8:39 pm
    I’ve already emailed them several times Mike..no replies for weeks!
  • Deleted User
    June 27, 2007 at 11:53 pm
    Hello,
    This problem with the limit on the memory has been fixed with the latest build of the decklink software 6.3 on the Blackmagic website http://www.blackmagic-design.com I believe.
    Leo
