Activity Forums Apple Final Cut Pro Legacy Any Free Roto program?
  • Any Free Roto program?
    Posted by Lokidrummer on December 3, 2005 at 10:47 pm
    Hi, i’ve looked around and can’t find a free rotoscoping program…is there one? The one with final cut just sucks, it’s not even rotoscoping, so any suggestions…i have a budget of about zero dollars and zero cents. Thanks
    -will
    Arnie Schlissel replied 20 years, 9 months ago 3 Members · 2 Replies
  • Jeremy Garchow
    December 4, 2005 at 2:22 am
    This ain’t free, but it works well;
    https://www.silhouettefx.com/roto/
    G5 Dual 2Ghz <> 4GB RAM <> FCP 5.02 <> Kona 2
    ATTO 42XS <> Huge Systems 4105 Fibre
  • Arnie Schlissel
    December 4, 2005 at 7:03 pm
    Cinepaint: https://cinepaint.movieeditor.com/
    It requires that you have X11 installed on your mac, and you’ll have to export the footage as a still image sequence. There’s no automation, so you’ll have to mask each frame one at a time. On the plus side, if you’re familiar with Photoshop, you shouldn’t have too much trouble learning how Cinepaint works. You should download & read the tutorial on using the flip book, since that’s the primary feature you’ll need to do any roto work with it.
    Arnie
    https://www.arniepix.com
