Activity Forums Compression Techniques Any experience in encoding for Mantis MC?
  • Any experience in encoding for Mantis MC?
    Posted by Dan Warvi on April 12, 2005 at 2:16 pm
    I have to encode a 2 1/2 min presentation cut in FCP at 1080i for a Mantis MC box just installed at a local museum. They’ve never used the thing before, and have no idea how to encode for it.
    Anyone have a cookbook for this box?
    Dan Warvi
    After Effects, Avid, Curious gFx, Broadcast Systems & PC as nec
    Charles Simonson replied 21 years, 5 months ago 3 Members · 2 Replies
  • Daniel_l
    April 12, 2005 at 3:29 pm
    Dan
    It accepts MPEG-2 (ATSC). I think Popwire Compression Master can handle the job, Apple Compressor can’t.
    DL
  • Charles Simonson
    April 12, 2005 at 4:00 pm
    If HD MPEG-2 encoding is your primary goal and concern, then bar none, the MainConcept Mac encoder will do the job, or Canopus ProCoder 2 on the windows side. Compression Master 3 currently has a limitation on output limited to either the same as source (up to 1080p), or if scaling is involved, then 1200×900. This should be fixed shortly though.
