Activity Forums Adobe After Effects Antialiasing text
  • Antialiasing text
    Posted by Petegeo on January 19, 2006 at 11:47 pm
    I know this a real “rookie” question but I have to get something out the door and don’t have time to continue searching. Always great to learn a program on the fly! You’d think I would know better.
    I’m doing a lower third in AE using animated text over a solid color. When I output it and move to my timeline it is aliased in a big way. I’m rendering in RGB + Alpha and have the best quality. The text is animated to fly in and out. What can I do to fix this?
    Thx in advance!!!
    Pete
    Joe Bird replied 20 years, 8 months ago 3 Members · 4 Replies
  • Steve Roberts
    January 20, 2006 at 1:54 am
    If you chose “straight alpha”, it will look like trash until it’s imported into an app that can recognize alpha channels. Then it will look fine.
    Hope that helps,
    Steve
  • Petegeo
    January 20, 2006 at 3:37 am
    Thanks Steve. I’ve render with both straight and premultipied channels and, although premultiplied looks slightly better, it is still not acceptable. I also have changed the alpha setting in Final Cut with no success. Is there a way to convert the text to outlines and still maintain the text animations? All other elements look great except the animated text.
  • Petegeo
    January 20, 2006 at 3:46 am
    One big Duh for me! When I view at 100% it looks much better. There’s still some artifact but nothing like what I thought I was seeing. Obviously, I would still like it to no have no artifact. Any advice on compressing the final piece to optimize the graphic elements or just compress as usual?
  • Joe Bird
    January 20, 2006 at 4:20 am
    Are you rendering to fields? Usually text looks pretty bad in the timeline from field redered animations. Can you preview your render on a broadcast monitor?
    If you want to compare, do a frame render, and a field render, look at each and notice that the frame render is pretty sharp. Of course the motion won’t be as smooth….
