Activity › Forums › Apple Final Cut Pro Legacy › Anti-Matte
Anti-Matte
Posted by Kevin Ham on September 27, 2006 at 11:01 pmI use Anti-Matte on an Avid where I can shape a matte around an object or person. I can then key another video clip under the matte on a separate video track.
Is there a way to do this in FCP?
Kevin Ham replied 19 years, 12 months ago 5 Members · 7 Replies -
Shane Ross
September 27, 2006 at 11:33 pmAnimatte. It is called an Animatte. And the closest you can get to that in FCP is an 8-point garbage matte, but it doesn’t have curves and bezier handles. There are mattes with more points out there…32point, 64point. All third party.
Nope…I sure miss my Animatte.
Shane
Littlefrog Post
http://www.lfhd.net -
The Lobby
September 28, 2006 at 12:04 amAnother option is to use the “Send to…” feature and create an animated matte in any number of other apps, Motion, Shake, AE, etc.
Kevin Ham
September 28, 2006 at 5:15 amSorry, should be Animatte. Do you know of a third party import that can make curves in FCP?
Kevin Ham
September 28, 2006 at 5:16 amI don’t have AE or Shake. I tried Motion but couldn’t get it to work the way I want it to. Wish there was a 3rd party plugin that I could use in FCP.
John Pale
September 28, 2006 at 5:29 am -
Sherwood Ball
September 28, 2006 at 8:30 amCHV is a little better than the FCPro garbage matte,
a little window in the corner shows a blow in of where you’re placing
your keyframe. But you basically have to drag the keyframes around the
object.Much easier to draw them in with the bezier handles.
Funny, I just posted about this above not knowing about his post.
Obviously needed and wanted by many.
SherwoodG5 Dual 2.5 GHz
4G Ram OSX4.6
Sata drives
Final Cut Pro 4.5HD, Logic Audio 7.1
PS CS2, AE CS2 -
Kevin Ham
September 28, 2006 at 3:19 pmAwesome! You guys rock!!!
Which would you recommend? CHV or silhouettefx?
