Activity Forums Adobe After Effects Anti Fisheye
  • Tudor “ted” jelescu
    March 26, 2012 at 6:55 am
    Well, the idea of the GoPro (and similar cameras) is the wide angle lens. However, if you want to remove some of the distortion (keeping in mind that you will loose part of the image and resolution), you can go under Effects> Distort > Optics Compensation, check “Reverse Lens Distortion” and adjust the FOV to about 73-75.
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Carr Lockwood
    March 26, 2012 at 10:41 am
    This is exactly what I was looking for thanks man
