Activity Forums Maxon Cinema 4D Anti-Aliasing Issue
  • Anti-Aliasing Issue
    Posted by Ken on April 30, 2007 at 6:00 pm
    Hi…
    I’m having a strange problem with jagged edges in my transparencies in a project I’m working on. The objects are simple cubes with a simple transparent material with a 1.5 fresnel refraction. The image below is rendered using 1×1/4×4 min/max anti aliasing. The jaggies go away when I increase it to 4×4/4×4 but my render time increases from a few seconds a frame to 3+ min per frame. Any help is greatly appreciated.
    https://www.pixel8studio.com/stage/c4d/jaggies.png
    Thanks in advance!
    Ken
    Adam Trachtenberg replied 19 years, 4 months ago 2 Members · 1 Reply
  • Adam Trachtenberg
    May 1, 2007 at 3:03 pm
    Unfortunatey the only solution is to bump up the AA. Have you tried the intermediate setting (2×2)? You may be able to speed things up by using the separate AA parameter in the compositing tag–applying higher AA to selected objects.
