Activity › Forums › Apple Final Cut Pro Legacy › anti-aliasing
anti-aliasing
Posted by Brett Juchniewicz on March 16, 2009 at 9:20 pmA quick question about anti-aliasing. If the amount is set to 1 in the filter tab, would that be enough to simply get rid of the aliasing without losing quality?
Richard Harrington replied 17 years, 5 months ago 3 Members · 3 Replies -
David Roth weiss
March 16, 2009 at 9:29 pmBrett,
If you want a precise answer, you’d best write a precise question.
We have no idea what’s aliasing, we have no idea what codec you’re using, and we have no idea what filter you’re setting that parameter for.
David Roth Weiss
Director/Editor
David Weiss Productions, Inc.
Los AngelesPOST-PRODUCTION WITHOUT THE USUAL INSANITY ™
A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, and Indie Film & Documentary forums.
Brett Juchniewicz
March 17, 2009 at 2:05 amIt regards lines that appear on the image of DV. If you were to pause it you will notice horizontal lines on the screen. I believe everything was shot within normal DV-NTSC standards but I don’t know the specifics since I got the footage from the producer.
Richard Harrington
March 17, 2009 at 3:29 pmThat is called interlacing
Not antialiasingit is supposed to be there
You can remove it when compressing for Web
Or remove it from freeze frames in PhotoshopFCP has an interlace flicker filter… but again.. it is supposed to be there and you shouldn’t generally remove it from DV footage
Richard M. Harrington, PMP
Author: Photoshop for Video, Understanding Adobe Photoshop, Final Cut Studio On the Spot and ATS:iWork
