Activity › Forums › DSLR Video › Another workflow question
  • Another workflow question
    Posted by Casey Petersen on June 4, 2010 at 3:57 pm
    I’m using the Canon 7D at 1080 30p.
    I have been searching the internet for the last hour trying to find the best description of a workflow for editing, and for straight DVD conversion…with little success regarding specific information I’m looking for, so I thought I’d post here.
    Everyone says it’s best to convert using MPEG Streamclip to XDCam or ProRes. That’s great…but I can’t find anyone that talks about the specific settings to use in MPEG Streamclip….
    Obviously, change “Compression” to Apple ProRes 422 or XDcam (but which one???).
    Quality to 100%,
    Sound – Uncompressed, Stereo, Auto
    Frame size – 1920 x 1080 (unscaled)
    Do I check anything under Frame Rate? Interlaced Scaling? Reinterlace Chroma? Deinterlace Video? How about Field Dominance?
    Obviously don’t zoom or crop.
    Second question…what’s the best way to go straight from the original h264 video files to DVD…I shot 30 mins. of video and want to give the client the rough footage to view. Do I need to convert to ProRes or XDCam before going to MPEG2, or is it okay to go straight to MPEG2 (using Compressor’s default – 90 minutes Best Quality…do I need to change any settings then?)
    THANKS IN ADVANCE!!!
    Casey
    Jonathan Ziegler replied 16 years, 3 months ago 3 Members · 6 Replies
  • Richard Harrington
    June 4, 2010 at 4:11 pm
    Can you start by telling us what you’re editing on and quality ofdrives you are using
    Richard M. Harrington, PMP
    Author: Video Made on a Mac, Photoshop for Video, Understanding Adobe Photoshop, Final Cut Studio On the Spot and ATS:iWork
  • Casey Petersen
    June 4, 2010 at 4:15 pm
    Oops…sorry…I’m used to posting on a Final Cut forum….
    I’m using Final Cut Studio 2 on a Mac Pro 2x3Ghz Dual-Core Intel Xeon, 10Gb RAM, running OSX Tiger. My hard drives are 2 Western Digital MyBook 1TB FW800 drives (does that make a difference?).
    Casey
    June 4, 2010 at 4:36 pm
    Use compressor. Choose prores preset that matches frame size
    Get raided drives
  • Casey Petersen
    June 4, 2010 at 4:44 pm
    Sorry, I’ve been a little overloaded with details (frame rates, sizes, interlacing, etc)…so much that my brain has gone a little mushy, and have gotten lost and can’t find my way back.
    I see the Compressor preset under Apple->Formats->QuickTime->Apple ProRes 422. I see that the Width & Height are 100% of source, and Frame rate is 100% of source. Codec type is ProRes HQ (does it need to be HQ?). Is that the right preset to use…do I need to change any of the settings?
    Also…in making a DVD of the rough footage…should I be using this ProRes preset in Compressor first, or is it okay to go straight to MPEG2?
    Casey
    June 4, 2010 at 4:57 pm
    HQ is overkill
    For DVD direct to MPEF 2 is fine
  • Jonathan Ziegler
    June 5, 2010 at 8:48 pm
    Hey there, if you are just showing rough footage like dailies/rushes (no editing), convert using Compressor to SD NTSC and use one of the DVD presets for the amount of footage you have and let it add letterbox bars. The files will be much smaller and since you won’t be editing, you can just drop them straight into the DVD Studio Pro timeline (don’t forget to do your audio, too unless they don’t need to hear audio) and make a DVD from that.
    Jonathan Ziegler
    https://www.electrictiger.com/
    520-360-8293
