Activity Forums VEGAS Pro Another Stupid question…
  • Another Stupid question…
    Posted by Martin Boulianne on May 22, 2005 at 12:26 pm
    Ok here goes…I’ve been playing around in my Prefs…. V5
    now when i save a project …and turn on (Copy and trim Media) all my .AVI’s have seperate audio .wav files …
    I use this to be able to save all my projects to DVD data..so i can reEdit them again if agait if a client changes his mind…( which does NOT happen often… 😉 )
    If i remember.. i used to only have .AVI with the sound within the avi…???
    any one know what i did to turn this on and how i put it back to only one file and not two!?!?!?
    Martin Boulianne
    tech.Dir.
    Martin Boulianne replied 21 years, 4 months ago 3 Members · 3 Replies
  • Donatello
    May 22, 2005 at 3:27 pm
    it the way copy-trim works .. you can’t turn it off other then don’t use copy/trim …
  • Edward Troxel
    May 22, 2005 at 6:14 pm
    If you want to keep the audio and video in a single AVI file, you’ll need to use the standard “render as” command. as donatello said, using that feature will give you the video in an AVI file and the audio in a separate WAV file.
    Edward Troxel
    JETDV Scripts
  • Martin Boulianne
    May 22, 2005 at 11:37 pm
    Ok so i didn’t do any thing wrong!! thanks…
    Martin Boulianne
    tech.Dir.
