Activity Forums Adobe Illustrator Another stupid Illustrator question.
  • Another stupid Illustrator question.
    Posted by Tim Kolb on August 10, 2005 at 4:08 am
    Logo was created in Illustrator.
    It was created using line thickness instead of creating the “lines” as outlines-based shapes.
    At this point, there is also some white solids apparently used as “masks” to create some of the non-standard letter forms from outline shapes…the result looks good…until you select all the objects and realize that the circular parts of the letter forms are simply solid circles with nested white circles to mask the center, etc.
    So now I need an outline version…am I doomed to have to trace the entire thing, or is there a way I can use the “pathfinder” function…or something else?
    I’m tempted to load it into Photoshop at a huge image size and do a color-based select and export it as an illustrator path and start it that way…it probably isn’t the most effective way, but it’s a way that I understand at least…
    As always, thanks for your help.
    TimK,
    Kolb Syverson Communications,
    Creative Cow Host,
    2004-2005 NAB Post Production Conference
    Premiere Pro Technical Chair,
    Author, “The Easy Guide to Premiere Pro” http://www.focalpress.com
    “Premiere Pro Fast Track DVD Series” http://www.classondemand.net
    Tim Kolb replied 21 years, 1 month ago 2 Members · 2 Replies
  • Kim Mackenzie
    August 11, 2005 at 3:16 pm
    Pathfinder should do what you need, though it’s hard to tell without seeing the logo. Probably Minus Front.
    If you need your lines to be outlined shapes instead of stroked paths, select the path, then go to the Object menu and select Path and Outline Stroke.
  • Tim Kolb
    August 12, 2005 at 2:10 pm
    Thanks Kim,
    The second suggestion did exactly what I needed. I appreciate the help.
    TimK,
    Creative Cow Host,
