Activity › Forums › Adobe Premiere Pro › Another seeker of a blur transition
  • Another seeker of a blur transition
    Posted by Glenn Angel on April 29, 2011 at 2:32 pm
    Hi PPLZ,
    ive done a search and the most recent enquiry was 2 yrs ago on how to make a blur transition!
    Surely there is a basic plugin 🙁 I jst changed from Vegas to Premiere due to MOV issues and im in the middl eof a wedding video and i need my BLUR!!!!
    Is there a way to get the transition or do i just have to key frame it 🙁
    Andy Prada replied 15 years, 5 months ago 4 Members · 3 Replies
  • Ann Bens
    April 29, 2011 at 3:34 pm
    Look under the presets: fast blur in/out
  • Chris Buttacoli
    April 30, 2011 at 4:00 pm
    The way I do it….
    With clip A and clip B on the timeline, I add a 1 sec crossfade between them. For clip A, I set the scale width from 100% to 300% over the last second and a half. I also add a fast blur from 0 to 35 over the same time. For clip B, I set the scale width from 300% to 100% over the first second and a half. The same with a fast blur, 35 to 0 over the first second and a half.
    I save these as presets in a folder I called ScaleBlur. The clip A effects are pinned to the out point. The clip B effects are pinned to the in point.
    Now, when I need to use this effect again, I just add the crossfade and drag the corresponding presets to the a and b clips.
  • Andy Prada
    May 1, 2011 at 9:57 am
    If you need a quick solution you could purchase Any FX from Pixelan for $29
    https://www.pixelan.com/afx/intro.htm
