Activity › Forums › VEGAS Pro › Another question: to sublip, or NOT to subclip. That is the question.
Posted by Ron Whitaker on June 16, 2015 at 7:59 pmI had an interesting reply on an earlier post of mine, where a Vegas user simply suggested that I not use subclips. Perhaps that’s what’s causing my problem.
But, if one is making a documentary, or a full-fledged movie, aren’t they pretty much needed?
Or, is just going through all the footage in the Trimmer, and then taking notes, sufficient in today’s world of film and video editing?
I’d like people’s thoughts on that.
Thank you.
Ron Whitaker replied 11 years, 3 months ago 4 Members · 17 Replies -
John Rofrano
June 16, 2015 at 8:12 pm[Ron Whitaker] “But, if one is making a documentary, or a full-fledged movie, aren’t they pretty much needed?”
Yup. Being able to separate the wheat from the chaff is first step in organizing an edit. 😉
[Ron Whitaker] “Or, is just going through all the footage in the Trimmer, and then taking notes, sufficient in today’s world of film and video editing?”
That seems archaic. The program should be helping you not making you use a pencil and paper.
This is a fundamental function of any NLE. I don’t know if too many subclass was your problem but you are editing using the correct workflow.
~jr
http://www.johnrofrano.com
http://www.vasst.com -
Ron Whitaker
June 16, 2015 at 9:38 pmThat’s what I thought. Subclips are useful, at least I thought they were supposed to be.
I’m at my wits end, though. I don’t know what to do. I’ve created several hundred in a project, and I can’t open any of the iterations of the project files I’ve created. It just hangs at around 80%.
John Rofrano
June 17, 2015 at 12:47 pmIt could just be a corrupt piece of media and have nothing to do with subclass at all. One way to test is to move the media somewhere else and then move it back a few at a time opening the project each time to see if it loads. When it stops loading, the last media you move back in is probably the problem.
~jr
Andrew Lenczycki
June 17, 2015 at 3:09 pmBuilding on what John R. has suggested (loading a few media files at a time): With several hundred media files, this could take some time. Load only the first half of your files – if it works then you know the culprit is in the last half of your files. This would cut down the files to investigate by 1/2. If the second half is problematic, then load the first half of those. If that causes your problem, then you know its in that group of files. Keep loading 1/2 the files at a time and determine whether it the first or second half that contains the file that’s causing the problem. If you have 300 media files you would narrow it down from 300 to 150 to 75 to 36 to 18 to 9 to 5 to 3… Hopefully you get the idea. In about 9 attempts you should be able to narrow the focus. Hopefully this makes sense.
Andrew Lenczycki
John Rofrano
June 17, 2015 at 4:43 pm[Andrew Lenczycki] “With several hundred media files, this could take some time. Load only the first half of your files – if it works then you know the culprit is in the last half of your files. “
Ah, yes… a Binary Search. I should have suggested that. 😉
~jr
Ron Whitaker
June 17, 2015 at 8:02 pmOK. I tried your suggestions. I moved a bunch of media files to another folder, opened Vegas, then clicked to open the latest .veg file for this project. Is that what I should be doing, or should I be starting a completely new project?
The good news is that the green slider at the bottom left goes all the way to 100%. The bad news is that it just sits there at 100%. If I mouse over the Vegas icon in the try, the pop-up indicates that it’s in “not responding” mode.
Also, to make sure I did this correctly, when I first moved a bunch of the files to a different folder, then opened Vegas, the text box appeared that it couldn’t find some of the files. So, I simply suggested that it ignore the files it can’t find and keep them offline. Is that correct?
Andrew Lenczycki
June 17, 2015 at 10:14 pmAs an aside, I was having lots of troubles with a Veg file with lots of media. Variety of issues, including files on the timeline becoming “invisible” one time, OK the next. Reading thru the forums, someone was having very random things happening with their files and they turned off GPU Rendering option. I tried this and haven’t had a SINGLE problem since then (and have worked on literally 30 + different veg files).
To answer your question, if it were me (and I’m NOT an expert), I would start a new project, and add half of your media to the project. Save, close the file and see if it reopens OK. If so, do the same with the 2nd half of your files, add them to the same new project, save, close the file and see if it reopens. If it has the “hanging” problem, then it must be one of the files in the 2nd half. I would then start a NEW project and add in 1/2 of the files from the previous (that was the problem group). Save, close the file and see if it reopens. If it does, add in the 2nd half of the files from the “bad” half, save, then see if you can reopen the veg file. What you’re trying to do is find the “problem” media file (assuming that’s the issue) as quickly as possible.
Andrew Lenczycki
Ron Whitaker
June 17, 2015 at 10:32 pmI’ll give that a try.
I wish there was a way to export to a file ONLY the subclip information for a project. That way if a file became corrupt, I could simply create a new project file, then import the subclip data.
Thing is, I don’t have anything on the timeline as yet. I’ve ONLY been going through the media files in the Trimmer window and creating subclips. That’s it.
John Rofrano
June 19, 2015 at 2:12 pm[Ron Whitaker] “Thing is, I don’t have anything on the timeline as yet. I’ve ONLY been going through the media files in the Trimmer window and creating subclips. That’s it.”
I like Andrew’s idea of creating a new project and importing all of the media and saving it and seeing if you can reopen it. If that works, then you know it’s not the media.
~jr
Aleksey Tarasov
June 19, 2015 at 2:41 pmThe latest Vegas versions allow you to import media from a project (File > Import > Media from Project).
Give it a try…Film grain for your digital footage
