Activity › Forums › Maxon Cinema 4D › Another Newby with a modeling problem
  • Another Newby with a modeling problem
    Posted by Scott James on March 30, 2010 at 10:20 pm
    I’m trying to learn 4D and I’ve been following a tutorial from a text book, but I can’t see where I’m going wrong! If anyone could shed light on this matter, I would be grateful x
    I’m trying to make a profile of a castle turret and I’ve done the following:
    1. F4 for front view
    2. 2.5D snapping
    3. Filter > Axis to uncheck
    4. Objects > Create Spline > Linear
    5. Created the profile
    6. With Points tool selected, I’ve selected several points
    7. Edit Spline > Chamfer
    and this is where I’m stuck as I can’t select any of the points to Chamfer!!! The tutorial says click and drag, but I can’t select the points to drag!
    This is probably very basic to all you guys, but I just can’t fathom it out. All ideas welcome, Thanks!
    Scott James replied 16 years, 6 months ago 1 Member · 1 Reply
