Activity Forums Apple Motion another newbie question
  • another newbie question
    Posted by Brian Pitt on November 16, 2005 at 4:49 pm
    i am working on a DV NTSC project and it keeps giving me an error messge that says: “This object is too large to render, and will be cropped. The maximum size is 2048 by 2048.”
    I am working in a 720 by 480 workspace, so that doesn’t make sense. Anybody know how to fix this?
    Brian
    Noah Kadner replied 20 years, 10 months ago 3 Members · 2 Replies
  • Arnie Schlissel
    November 16, 2005 at 6:23 pm
    One of your source files, or perhaps a layer, is bigger than that 2k size. Are you working with stills? Or, perhaps, you’re using particles? Once you identify the culprit layer, you can make that layer ‘fixed resolution’ in the inspector. I think there was a tutorial specifically about setting layers to fixed resolution here on the cow a couple of months ago. It explains the issue rather well.
    Arnie
    https://www.arniepix.com
  • Noah Kadner
    November 16, 2005 at 6:34 pm
    As a newbie you probably don’t know but it’s considered polite to respond to follow up questions that arise from your initial post before starting another…
