Activity Forums Adobe After Effects another newbie alpha problem
  • another newbie alpha problem
    Posted by Hunter Christy on July 28, 2006 at 2:17 am
    ok. check-check it.
    a man runs into frame. as he runs into frame, he bursts into flames.
    i made vector paint of 160 frames of video. exported on the paint as a tiff sequence.
    the reason i did this was to use the alpha channel as a track matte sequence for particlellusion.
    but. the problem was that i couldnt seem to get the darn alpha channel in the tiff sequence: i had to open EVERY picture in photoshop and add the alpha channel, copying the info from the RGB.
    it worked, but there MUST be an easier way.
    please? anyone?
    thanks,
    hunter
    Hunter Christy replied 20 years, 1 month ago 2 Members · 2 Replies
  • Mylenium
    July 28, 2006 at 5:50 am
    Knoll Unmult, Walker Alpha Tool or most simply you could have started out telling your brushes to als work on Alpha and use a respective output module in AE…
    Mylenium
    [Pour Myl
  • Hunter Christy
    July 30, 2006 at 11:28 am
    ok. how exactly do i do this?
    again. i am very new.
