Activity › Forums › Apple Final Cut Pro Legacy › Another Newb Question
  • Another Newb Question
    Posted by Chris Baker on October 27, 2010 at 3:07 pm
    Ok in Avid if you had a time code problem on tape you could either make the preroll less or more or digitize across timecode breaks. I see neither of these options anywhere, looks like your stuck with a 3 second preroll. Is it an option I missed?
    Visit us at;
    http://www.frogpondproductions.biz
    (860)884-6015
    The creative urge is the demon that will not accept anything second rate.
    -Agnes DeMille
    Mark Suszko replied 15 years, 11 months ago 3 Members · 2 Replies
  • Michael Sacci
    October 27, 2010 at 6:06 pm
    Where are you looking?
    But preroll and TC issues are two different things. Preroll is a problem if you are logging a clip an want to start on frame 12 but the TC starts on frame 10. (can be changed to 1 sec in Device Control Preset Editor)
    TC issues is if there are TC breaks in the Tape. There is a setting to tell FCP what to do on TC breaks, like make a new clip. Found under Final Cut Pro> User Prefs>General Tab, right side.
    Which is your problem?
  • Mark Suszko
    October 28, 2010 at 1:56 am
    You could also switch the deck control to “uncontrolled device”, just for this one part, roll the tape manually, and hit “capture now”. Still gets you the time code, but you don’t have to worry about the machine losing itself and forever seeking back and forth.
