Activity › Forums › Apple Final Cut Pro Legacy › Another Multi-clip snafu
  • Another Multi-clip snafu
    Posted by Daniel Schultz on February 9, 2010 at 12:46 pm
    Hello all,
    Trying to multi-clip two camera angles from two different cameras: HMC-150 and a Canon (forget model number). I ran camera one, the Panny 150, and the photographer ran the DSLR. We both set to 1080/30p. I set the timecode to 0 at the slate/clapper for both, but when I tried to set as mult-clip, FCP said they were different frame rates.
    I checked, and sure enough, the Canon was 30fps and my panny was 29.97. So I put the Canon through cine tools and converted it to 29.97. Tried again, this time the error message is “different codecs.” The Panny codec is Pro-res, so I tried exporting the Canon clip from the timeline at what I thought was the same codec–1080 pro-res, then reimporting that.
    Same error message–different codecs, would not multi-clip.
    Anyone have any tips on getting these two to match up for a multi-clip?
    Thanks in advance.
    Dan S.
    Daniel Schultz replied 16 years, 7 months ago 4 Members · 7 Replies
  • 7 Replies
  • Daniel Schultz
    BTW, I”m running FCP 6.0.6 on a new MacBook Pro 17″, 8gb memory.
    Dan S.
  • Arnie Schlissel
    February 9, 2010 at 2:14 pm
    [Daniel Schultz] “Same error message–different codecs, would not multi-clip.”
    That’s your answer. You need to conform both clips to the same codec and frame rate. BTW, this is in your FCP manual.
    Arnie
    Post production is not an afterthought!
    https://www.arniepix.com/
  • Daniel Schultz
    February 9, 2010 at 2:21 pm
    Do I do that in FCP or Cine Tools? (and I will check the manual)
    Dan S.
  • Michael Sacci
    February 9, 2010 at 4:17 pm
    you convert codecs in Compressor.
  • Daniel Schultz
    February 10, 2010 at 7:34 am
    Okay, I thought I did everything right.
    I changed the codec to pro res progressive HQ in compressor.
    Then I changed the frame rate from 30fps to 29.97fps, to match the clip from camera 1.
    Still get the same message: “Can’t make multi-clip because they’re different codecs.”
    Thoughts anyone?
    Dan S.
  • Jerry Vogt
    February 10, 2010 at 11:03 pm
    I had this same problem 6-months ago. FCP does not support the multi-cam feature with the Pro-Res timeline.
    Jerry Vogt
  • Daniel Schultz
    February 11, 2010 at 3:07 am
    So then what the !@#$# should I do?
    Dan S.
