Activity › Forums › Adobe Premiere Pro › Another mulicamera question (CS4.1)
  • Eric Monroe
    July 15, 2009 at 5:05 am
    Just curious…….why do you not want the cuts in your audio? When you final render it they won’t be there.
    However, you can stop it from happening. Once you setup your nested sequence, click the audio track and pull it down to track 2. From there enable your multicam, open the multicam window and edit as normal.
    Ppro’s multicam’er only cuts to video/audio track 1. So by leaving the video on track 1 and dragging the audio to track 2 it will cut the video and not the audio.
    When you have finished the multicam, simply grab the audio and move it back up to track one.
    (I just did it to make sure it works)
    Whallah! :o) hope this helps ya.
    Eric Monroe
    Shadow Studios
