Activity Forums VEGAS Pro Another MTS to .AVI converter?
  • Another MTS to .AVI converter?
    Posted by Norman Willis on July 17, 2009 at 8:01 am
    I don’t get it. I had Cineform converting MTS files to .avi just yesterday…and now it is not working again. It says “No audio stream detected.”
    The only change I made was to bump the swap file from 16MB to 12GB. (And I think I will go put it back down).
    But is there another MTS (AVCHD) to .avi converter that is compatible with Vegas Pro 9, x32 and/or x64?
    Thanks.
    Norman Willis
    http://www.nazareneisrael.org
    servant@nazareneisrael.org
    Norman Willis replied 16 years, 1 month ago 4 Members · 7 Replies
  • 7 Replies
  • John Rofrano
    July 17, 2009 at 10:59 am
    Changing the swap file size could now have affected this. Put it back down and see. Something else must have changed.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Norman Willis
    July 17, 2009 at 5:37 pm
    I’ll try it after this project.
    Norman Willis
  • Norman Willis
    July 20, 2009 at 4:07 am
    Hi John.
    Jake Seagraves of Cineform writes:
    >>Windows updates do not usually effect CineForm software. In fact, we prefer that you have all the latest windows updates installed. Swap disk should also not make a difference.
    I think I am going to close this project out, and then I will try tweaking everything again. If Cineform ran twice before, it should run again.
    Thanks.
  • John Rofrano
    July 20, 2009 at 10:56 am
    That was a typo on my part. I meant to say that the swap file could NOT have affected it but I typed a “w” instead of a “t” which gave it a whole different meaning. Wow, sorry about that. Jake is correct, the swap file should not make a difference.
    ~jr
  • Simon Boyle
    July 26, 2009 at 9:40 am
    I know one named AVCHD(m2ts/mts) Video Converter that can convert the mts hd video to many other video formats.
    If you want a try, here:
    https://blog.flvto.net/m2ts-to-avi-converter/
    Hope it is helpful.
  • Lacy Jee
    August 6, 2009 at 9:28 am
    The M2TS files can be converted in AVI file format, by making use of a converter, M2TS to AVI Converter.This can efficiently make a conversion of your M2TS files.
    Steps for Converting M2TS files in AVI format:-
    1.Install the M2TS to AVI Converter, and run it.
    2.Add M2TS files for conversion. Make an addition of multiple files at a time.
    3.Press “Start” button to begin the process of conversion M2TS to AVI.
    4.Now, the results of conversion will be displayed to you on the screen.
    5.The process of conversion of M2TS to AVI has finished now, so enjoy with the converted files.
  • Norman Willis
    July 23, 2010 at 3:43 pm
    Hey Nathan,
    They upgraded Cineform, and it works great now…but thanks! That’s good to know.
    Norman Willis
