Activity Forums VEGAS Pro Another midi controller question for audio in Vegas
  • Another midi controller question for audio in Vegas
    Posted by Ted Snow on September 19, 2010 at 6:56 am
    I have an Evolution UC-33E midi controller which I set up to work with Vegas for controlling my audio channels during mixdown of audio. I have got the controller working OK…but…when I stop moving the fader on the controller…the volume level on the track in Vegas jumps back up (or down) to the default volume setting it was last set at manually. For instance…if the level is set at 75% via the volume envelope, I can pull down the fader which is assigned to that particular channel and the level will change in real time as the fader is pulled. But when I stop moving the fader…after about one or two seconds the level will jump back up to 75%…in essence making your level change null and void. Is there a setting somewhere I am overlooking that will fix this? I would like to use this midi controller for audio mixdown but it’s useless if the track levels jump back when you stop moving the fader. Any suggestions?
    Ted
    Ted Snow replied 15 years, 11 months ago 1 Member · 0 Replies
  • 0 Replies
