Activity Forums Adobe After Effects Another loop problem…
  • Another loop problem…
    Posted by Pablito on November 9, 2006 at 4:24 pm
    Hi…
    I am trying to made a simple animation…
    I have an object that begin to rotate and its rotation speed increases then it go on rotating at a constant speed but I’m having trouble….
    I tried 2 options…
    1st
    2 keyframes….
    1st keyframe: rotation=0
    2nd keyframe: rotation=+20
    I use the graph to create an increasing speed and a loop (“continue”) expression to keep the object rotating after the second keyframe but the speed decreases just after the second keyframe… If I try to adjust the expression graph the object begins to rotate but in the reverse way (before the keyframe it rotates Clockwise, after it rotates counter-clockwise)
    1st
    3 keyframes…
    3rd keyframe: rotation=+21
    same loop expression as before
    same behaviour as before…
    Can someone help me, please?
    Pablito replied 19 years, 10 months ago 1 Member · 0 Replies
  • 0 Replies
