Activity › Forums › Adobe After Effects › another layer marker / expressions question
  • another layer marker / expressions question
    Posted by Sam Young on June 8, 2006 at 3:19 am
    is there a way, using expressions, to count the number of markers on a layer? if so, would it be possible to call on the “index” value of a marker on a layer much in the same way you can call on the index (stacking order) of a layer in a comp?
    Dan Ebberts
    replied 20 years, 3 months ago
    3 Members · 2 Replies
  • Mylenium
    June 8, 2006 at 5:14 am
    Yes, you could do that. Not sure off the top of my head, but there should be a thisLayer.numMarkers method which would give you exactly what you need.
    Mylenium
    [Pour Myl
  • Dan Ebberts
    June 8, 2006 at 1:23 pm
    You get the number of markers this way:
    layer.marker.numKeys
    (or just marker.numKeys if the expression is applied to the layer with the markers)
    You’d use the marker index this way:
    n = 5;
    t = layer.marker.key(n).time;
    Dan
