Activity Forums AJA Video Systems Another IO (final cut issue)
  • Another IO (final cut issue)
    Posted by Rick Neely on October 12, 2005 at 5:01 am
    Hello…. again,
    noticed a simple problem I’m having-
    I am having difficulty playing some sequences in some projects completely, because the audio cuts out. The video plays fine and continues, but the audio output stops. I’ve tried the following–
    – changed from unlimited RT to safe RT back to unlimited and so forth
    – rebooted both FCP, and the g5, and recycled the io, and trashed the preferences
    – closed any additional open sequences and running programs
    – lowered the audio levels on sequences
    – Checked for latest io drivers
    Can anyone else suggest something? It is really starting to create delays and aggravation when it comes to client previewing and outputs to tape. Thanks.
    RN
    Steve Covello replied 20 years, 11 months ago 7 Members · 9 Replies
  • 9 Replies
  • Chris Tompkins
    October 12, 2005 at 11:30 am
    Did you “Mix Down” your audio b/4 playback?
    I don’t think the volume of your audio would effect playback…
    Chris
  • Rick Neely
    October 12, 2005 at 8:10 pm
    I think so,
    but let’s pretend I’m an idiot so we can be sure. How do I check or perform an audio mixdown?
    Rick
  • Chris Tompkins
    October 13, 2005 at 2:33 pm
    Select all audio in the timeline and go to:
    Sequence
    Render Only
    Mixdown
  • Mike Laur
    October 13, 2005 at 3:21 pm
    Rick
    I feel your pain. This has been dogging us since we switched to FCP5/IO La on a G-5
    The audio just cuts out. During capture, during playback, during editing. Random, frustrating, annoying. It’s not a mixdown fix – this happens with only a single clip in the entire project.
    We tried all the usual things, just as you did. Rudy at AJA suggested terminating the Genlock Out on IO. I tried that (with a genlock signal going in, of course) and I tried switching the Control Panel settings between Genlock and Freerun as well.
    Same Audio Cut-Outs.
    Rudy also suggested that I had a bum IO box. Any other users’ feedback on this issue would be appreciated so we can figure out why this is happening, fix it, and get back to editing
    Mike L
  • Jeremy Garchow
    October 13, 2005 at 8:15 pm
    Does it happen in the same place every time?
    Have you tried deleting your render files?
    Is the project an upgrade from 4.5?
    G5 Dual 2Ghz <> 4GB RAM <> FCP 5.02 <> Kona 2
    ATTO 42XS <> Huge Systems 1.25 TB 4105 Fibre
  • Mike Laur
    October 13, 2005 at 8:45 pm
    Thanks Jeremy:
    No, it happens at different places in a clip, and with different clips. Random.
    It happens even if there are NO render files. It happens in capture and playback.
    And all of the projects originate with FCP 5.0.2.
    Mike L
  • Dave Jenkins
    October 14, 2005 at 3:07 am
    Have you tried monitoring the audio thought the computer? If it’s okay then I would think it’s the AJA box.
    Dajen Productions
    Santa Barbara, CA
    G5 Dual 2 Gig – AJA IO & LA
    Huge 1.2 Raid
    FCP 5-OS X 10.4.1-QT 7
  • Andy Edwards
    October 17, 2005 at 5:19 pm
    How full are your video drives? If you drives are full and you are cutting from one clip on the outside of the drive to a clip on the inside of the drive platter, you might experience some drop out.
    Have you rendered out your entire sequence?
    Andy
  • Steve Covello
    October 23, 2005 at 2:33 pm
    Had the same problem. Moved the dead clips to another track. Problem occurred only on export QT’s and AIFF’s for a while too but not on timeline playback.
    steve covello
    double wide post
