Activity Forums Panasonic Cameras Another inquiry for Jan
  • Another inquiry for Jan
    Posted by Christopher Wright on October 17, 2008 at 3:11 am
    I just saw an online ad for the AG-HMC150, which looks almost exactly like the AG-HPX170, but without some of the advanced features built in. I know it is AVC format versus P2, doesn’t have the slo-mo and speeded up frame rates available, or the SDI out, but, I really like the idea that it shoots (3) hours at the highest quality setting on an inexpensive 32GB SDHC card!
    My main questions are:
    are the 1/3″ chips the same on both cameras?
    does the AG-HMC150 have the same improved low lux performance as the HVX-200A and the HPX-170 (better than the old HVX-200)?
    Is the lens exactly the same as the one on the HPX?
    What is the quality of your AVC to DVCPROHD software transcoder for Windows?
    Does the 720P24Pn Intraframe QT codec play well with the P2 QT 720p24Pn codec in FCP (in a 720P24pn timeline), or is it better/preferred to transcode to DVCPROHD first (your free Panny software now only available on Windows?)?
    Does the audio record at 48 or 32kz??
    Is it actually better at motion shots than either the HVX or HPX?
    If all of this is true, it might make an ideal B-roll camera for my HVX, and a lot less expensive than the HPX..
    Dual 2.5 G5, IO, Kona LH, IO, Medea Raid, UL4D, NVidia 6800, 4Gig RAM
    Octocore 8 GB Ram, Radeon card, MBP, MXO
    Windows XP Adobe Studio CS3, Vegas 8.0, Lightwave 9.2, Sound Forge 9, Acid Pro 6, Continuum 5, Boris Red 4, Combustion 2008, Sapphire Effects
    Noah Kadner replied 17 years, 11 months ago 6 Members · 8 Replies
  • 8 Replies
  • Steve Eisen
    October 17, 2008 at 11:45 am
    Read about it here:
    https://catalog2.panasonic.com/webapp/wcs/stores/servlet/ModelDetail?displayTab=O&storeId=11201&catalogId=13051&itemId=274232&catGroupId=112502&surfModel=AG-HMC150
    Steve Eisen
    Eisen Video Productions
    Board of Directors
    Chicago Final Cut Pro Users Group
  • Jan Crittenden livingston
    October 17, 2008 at 12:31 pm
    [Christopher Wright] “My main questions are:
    are the 1/3″ chips the same on both cameras? ..”
    Yes.
    [Christopher Wright] “does the AG-HMC150 have the same improved low lux performance as the HVX-200A and the HPX-170 (better than the old HVX-200)? ..”
    Yes.
    [Christopher Wright] “Is the lens exactly the same as the one on the HPX? ..”
    Yes.
    [Christopher Wright] “What is the quality of your AVC to DVCPROHD software transcoder for Windows? ..”
    There is no such thing as a free lunch. Once you have compressed to even 21mbs, you have given ingformation away. Is it better thatn HDV, sure, is it as good as DVCPRO? No.
    [Christopher Wright] “Does the 720P24Pn Intraframe QT codec play well with the P2 QT 720p24Pn codec in FCP (in a 720P24pn timeline), or is it better/preferred to transcode to DVCPROHD first (your free Panny software now only available on Windows?)? ..”
    You will need to transcode in order to have an easy time of it and not degrade the signal eveven more in the edit process.
    [Christopher Wright] “Does the audio record at 48 or 32kz?? ..”
    Compressed.
    [Christopher Wright] “Is it actually better at motion shots than either the HVX or HPX? ..”
    No way. Intraframe recording will always be better than interframe long GOP.
    [Christopher Wright] “If all of this is true, it might make an ideal B-roll camera for my HVX, and a lot less expensive than the HPX..”
    I would advise to go with the HPX.
    Best,
    Jan
    Jan Crittenden Livingston
    Product Manager, HPX500, HVX200, DVX100
    Panasonic Broadcast & TV Systems
  • Jeff Brown
    October 17, 2008 at 12:48 pm
    [Jan Crittenden Livingston] “Intraframe recording will always be better than interframe long GOP.”
    Take this with a grain of salt: Jan is a Panasonic employee, after all. I do love Panny gear, but good long GOP will be better than bad intraframe. Shouldn’t be hard to imagine that. May not be the case in current product offerings, but such a sweeping statement just won’t hold in all cases.
    -jeff
    October 17, 2008 at 12:55 pm
    [Jeff Brown] “Take this with a grain of salt: Jan is a Panasonic employee, after all. I do love Panny gear, but good long GOP will be better than bad intraframe. Shouldn’t be hard to imagine that. May not be the case in current product offerings, but such a sweeping statement just won’t hold in all cases.”
    Actually I can prove it in all cases, if the camera is moving. I am a product manager at Panasonic and it is part of my job to understand the impact of compression of the output of a signal. I have been a party to many compression breaking tests and I have seen them all fail, but the ones that fail first are the long GOP codecs.
    And BTW, the question was adressed to me(notice the title of the thread) in the first place and since I am familiar with both of these cameras, I responded as I see the two cameras working and fitting into the scheme of what is out there. The DVCPRO HD codec will be more robust that the long GOP of AVCHD, and AVCHD is more robust than HDV. Even Sony says this, they equate 9mbs level of AVCHD to HDV. So yes while I am a Panasonic employee, I do try to give the most honest answer that 35 years in this industry can muster.
    Jan
  • Jeff Brown
    October 17, 2008 at 7:55 pm
    [Jan Crittenden Livingston] “And BTW, the question was adressed to me(notice the title of the thread)”
    I did see the title in passing… but I believe this is a public forum. I think if you read your post again, you’ll see you pretty much agreed with my point.
    I’m not bashing: I’ve been trying to get my clients to switch from Sony to Panasonic. If I have to work with compression these days, I would rather have intraframe. But the gross generality was like saying “film will always be better than video.” Good video is better than crap film. I think there’s a parallel; it would depend on the implementation of the codec, data rates, not to mention the imaging chip, lens, etc. I certainly wouldn’t argue with your assessment of the 2 cameras in question. I just had to be picky about what seemed to be an edict.
    -jeff
  • Bjoern Adamski
    October 17, 2008 at 10:35 pm
    What is “good Long-GOP”?
    Long-GOP performs well with low action but with very fast action it can end up in incalculable compression artefacts. The hardest test is filming a flurry of camera flashes.
    Product Manager
    MXF4mac
    https://mxf4mac.com
  • Christopher Wright
    October 18, 2008 at 5:59 pm
    Thanks for the clarification on the two cameras Jan. As always your professional input is much appreciated. I had already looked at all the product info (including the link that Steve provided), but of course the specific answers to the questions I needed weren’t there. Since these cameras are your “babies” I thought I would go straight to the source! I am still wondering after you encode from the AVC to DVCPROHD codec in your Windows software transcoder, if the audio rate comes out at 48kz or 32kz. If 48, it should indeed work well with the HVX FCP workflow.
  • Noah Kadner
    October 18, 2008 at 9:27 pm
    Just wanted to add that Jan is the straightest shooter you’ll ever find working for any of the ‘big time’ companies. Yes of course she is with Panasonic first and foremost, but she truly believes in what she says and is 100% right on the money. You want an honest technical appraisal- listen to what Jan has to say.
    Noah
    My FCP Blog. Unlock the secrets of the DVX100, HVX200 and Apple Color and Win a Free Letus Extreme.
    Now featuring the Sony EX1 Guidebook, DVD Studio Pro and Sound for Film and TV.
    https://www.callboxlive.com
