Activity Forums Adobe After Effects Another Grow Bounds question
  • Another Grow Bounds question
    Posted by Kay Winnstean on October 24, 2010 at 8:10 pm
    I have watched the Grow Bounds tutorial and looked in the archives of this forum to answer my question, but unsuccessfully.
    I understand that the Grow Bounds effect must be at the top of the stack of my other effects, but how does this apply to a group of compositions that have been pre-composed? Does it matter? I am creating a Spinning Orb and want to scale down the composition over another layer of footage, but am having no luck getting the effect to work.
    Thanks.
    Walter Soyka replied 15 years, 11 months ago 4 Members · 5 Replies
  • Kay Winnstean
    October 25, 2010 at 1:22 am
    Yes. When I scale the orb comp down over the footage, you can see the rectangular boundaries of the comp. I want to expand the edges of the orb composition to the edges of the layer beneath.
  • Michael Szalapski
    October 25, 2010 at 1:20 pm
    Grow bounds does not make a composition larger. It merely makes the work area of a layer larger when applying effects (such as Shine) that work on a layer’s bounding area.
    You will need to make the composition size of your precomp bigger.
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • Kevin Camp
    October 25, 2010 at 2:42 pm
    you could try using motion tile or cc repetile to increase the layer/precomp size. both those effects will tile the layer they are applied to.
    motion tile will just repeat or mirror the layer, repetile has several options for repeating the layer, along with a blend option that will feather the edges to help blend the edges.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Kay Winnstean
    October 25, 2010 at 11:52 pm
    Ah– that works! Seems obvious now.
    Thanks, Mike!
  • Walter Soyka
    October 26, 2010 at 6:15 am
    Another option is to enable the Collapse transformations switch for your precomp layer.
    Walter Soyka
