Activity Forums Panasonic Cameras Another greenscreen (paint) question
  • Another greenscreen (paint) question
    Posted by Dusty Powers on March 16, 2006 at 5:23 pm
    Has anyone used any greenscreen paints other than Roscoe with any success? I’m prepping for a Varicam shoot on very large greenscreen set which has to be painted and I’m trying to save on a bit of cost.
    dp
    Dusty Powers Video, Inc.
    Coastal NC
    910-520-5240
    Steve Wargo replied 20 years, 5 months ago 6 Members · 8 Replies
  • 8 Replies
  • Steve Wargo
    March 17, 2006 at 8:10 am
    We have used a lot of different greens and all very successful. Chrome Key green is made for “Ultimatte” machines and that box looks for a particular color with a lot of yellow in it.
    Do this: Go to your local Art Supply Store and find their Foam Core cards. They come in lots of colors including a bright green, about 18″ x 24″ and around $5. Test this green with your camera. After you’re completely amazed at how well it works, take the card to a paint store and have them match the color. A gallon flat washable paint is around $17 to $20.
    Light your background at 40%, caucasion skin at 70%, keep your subject 12′ away from the wall, side light them with a touch of magenta.
    Simple stuff.
    Steve Wargo
    Tempe, Arizona
    It’s a dry heat!
  • Ray Palmer
    March 17, 2006 at 7:34 pm
    [Steve Wargo] “Light your background at 40%, caucasion skin at 70%, keep your subject 12′ away from the wall, side light them with a touch of magenta.”
    And if your subject is wearing white and any of the green reflects onto their shoulder, wash their shoulder with amber or yellow light. This changes the green reflected light to another color that won’t “key”
    Ray Palmer, Engineer
    Salt River Project
    Phoenix, AZ
    602-236-8224 office
    There are three types of people in this world, those that can count and those that can’t.
  • Leo Ticheli
    March 17, 2006 at 7:44 pm
    I think it’s a very bad idea to try to change the color of the spill with an amber or yellow kick.
    In the first place, you can’t “dye” light colors; light doesn’t work that way. More importantly, you now have a strange, unmotivated colored edge on the subject that looks like a bad key problem.
    I light my screens to 60%. Test to see what works best for your screen and keyer.
    Good shooting!
    Leo
  • Dusty Powers
    March 18, 2006 at 2:54 pm
    Thanks for the input. I was told that a one gallon can of the Rosco paint was a bit expensive and I need to paint a wall the size of a two story building as well as the floor.
    dp
    Coastal NC
    910-520-5240
  • Dusty Powers
    March 18, 2006 at 3:05 pm
    How good is the greenscreen scene file setup for the Varicam that has been floating around? Is it worth downloading and include it when I shoot my tests? Do you know what menu changes are made on this particular scene file that may be helpful with keying?
    dp
    Coastal NC
    910-520-5240
  • Bruce Schultz
    March 18, 2006 at 9:59 pm
    Leo is absolutely right. Coloring back lights and side lights is a throwback to the Chroma Key days when switchers used simple ON/OFF routines to key with. Ultimatte, Primatte, and all of the NLE keyers now use very sophisticated alogrithms which easily differentiate between foreground and background and remove the green and blue spill electronically. You have more chance of hurting yourself with straw and amber gels than helping the situation.
    Bruce Schultz
  • Steven Bradford
    March 21, 2006 at 4:09 am
    This is true. However Rosco is actually the cheapest paint available. You don’t have to use Ultimatte Green though, you can use Chromakey green which is cheaper, unless you’re using Ultimatte Hardware for matting. Also, you can order the paint in five gallon containers.
    Anyways, the one problem you’ll have with getting it mixed is that it may not be flat enough and may glare on you. Ask the paint store for their flattest formulation possible. The Rosco paints are very very flat. If you’re just painting the wall, this may not be an issue, but if you’re painting the floor, glare becomes more of an issue.
    You might want to check out my web page on the subject.
    https://www.seanet.com/~bradford/bluscrn.html
    Steven Bradford
  • Steve Wargo
    April 6, 2006 at 7:53 am
    Leo got me on this one. When we light for green screen that will be processed on a Discreet Flame, we light the green at 40%. Otherwise, we’re closer to 60% as my collegue suggests. Some think that you need to flood the green with light when actually, the opposite is best. Also, you only need to key the area directly surrounding the talent and create a mask to cut the image beyond that.
    Also, when we shoot GS with a 16×9 camera, we turn the camera on it’s side and fill the imager with as much subject as possible, making the surrounding edge as clean as we can.
    Steve Wargo
    Tempe, Arizona
    It’s a dry heat!
