Another face tracking problem
I’ve followed this tutorial
https://www.youtube.com/watch?v=ulH-pumQbO8
and a second one from the same guy. Everything works fine, but when as soon as I start pickwhipping my puppet pins to my face track data (pin 1 to inner left eye, etc.) everything goes awry. The image shoots out to the left, stretching into a sharp point. Every pin I assign does the same thing until the “face mask” I’m applying to the video beneath it is all stretched to the left. (See Image Below)I’ve used a video “face mask” and I’ve used a graphic with an alpha channel showing only a static face mask. Same result.
Anybody else seen this before? Any solution? Any idea what I’m doing wrong?
