another example of intermittent bad audio
Posted by Will Hunter on November 30, 2011 at 9:55 pmHere is another even worse example where not only does the audio sound distorted but it actually fades out too.
Help!
Peter Groom replied 14 years, 9 months ago 4 Members · 3 Replies -
Ty Ford
December 1, 2011 at 12:49 amHello Will and welcome to the Cow Audio Forum.
Both sound like either a failing solder joint or a bad connection.
That they come and go is weird. I’d shake and wiggle all my audio connections and cables to see if I could make it happen.
I did know a guy with a studio in Boston that was taking radar hits from Logan Airport every time the array swung around past his attic studio…
Regards,
Ty Ford
Cow Audio Forum Leader
Want better production audio?: Ty Ford’s Audio Bootcamp Field Guide -
Craig Alan
December 1, 2011 at 4:34 amI’ve heard that pattern when the batteries in a field mixer grow weak and then die. But not on again off again.
OSX 10.5.8; MacBookPro4,1 Intel Core 2 Duo 2.5 GHz MacPro4,1 2.66GHz 8 core 12gigs of ram. GPU: Nvidia Geoforce GT120 with Vram 512. OS X 10.6.x; Camcorders: Sony Z7U, Canon HV30/40, Sony vx2000/PD170; FCP 6 certified; write professionally for a variety of media; teach video production in L.A.
Peter Groom
December 5, 2011 at 3:34 pmIve heard this type of issue twice before.
Once it was (as already suggested) batteries nearing end of life, the other time it was a phantom power supply about to die.
PeterPost Production Dubbing Mixer
