Activity Forums VEGAS Pro Another dumb render question
  • Another dumb render question
    Posted by Rick Wise on March 2, 2013 at 12:56 am
    I’ve searched here for an answer, but found none that work. I have original footage that is “custom 720×368, 23.976 fps”. The only render format that I can find that allows me to have the render “allow source to adjust frame size” is the lower-quality Main Concept AVC/AAC. All other formats gray out the frame size and do not include the “allow source to adjust frame size.”
    Question: is there a high quality render format I can use which will preserve the 720×368 size?
    Rick Wise
    Cinematographer
    San Francisco Bay Area
    https://www.RickWiseDP.com
    Rick Wise replied 13 years, 6 months ago 3 Members · 7 Replies
  • 7 Replies
  • Rick Wise
    March 2, 2013 at 3:36 am
    I left out: all I want to render is one minute of a scene from Jarhead to illustrate a lighting point for my students. So really good quality would be good.
    Rick Wise
    Cinematographer
  • Steve Rhoden
    March 2, 2013 at 1:18 pm
    Haven’t seen you in a while…..
    Do you have the Project Properties already set to
    720×368, 23.976 fps and then try rendering using the AVI format?
    Steve Rhoden
    (Cow Leader)
    Film Editor & Compositor.
    Filmex Creative Media.
    https://www.facebook.com/FilmexCreativeMedia
    1-876-832-4956
  • Rick Wise
    March 2, 2013 at 4:14 pm
    Hi, Steve, yes been a while. And yes, the properties are set to those dimensions. And yes, I’m trying AVI — but can use any format provided it will run on a Mac at school. (Via flash stick.) I am trying to preserve as much of the original quality as possible. Since it’s only a minute clip, size is not much of an issue.
    Rick Wise
    Cinematographer
  • John Rofrano
    March 2, 2013 at 5:10 pm
    [Rick Wise] ” I’m trying AVI — but can use any format provided it will run on a Mac at school.”
    AVI is the native windows format. You want MP4 or MOV for a Mac.
    [Rick Wise] “The only render format that I can find that allows me to have the render “allow source to adjust frame size” is the lower-quality Main Concept AVC/AAC”
    I’m not sure what you mean by “lower-quality”. You can render any quality your want with MainConcept AVC and it will let you use a custom frame size. Start with the Apple iPod 640×480 Video template and increase the bit rate to 25Mbps if you’d like. That should be plenty of quality. 😉
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Rick Wise
    March 2, 2013 at 6:03 pm
    Great! I’ll try that. Many thanks, John.
    Rick Wise
    Cinematographer
  • Steve Rhoden
    March 2, 2013 at 11:23 pm
    Did that work Rick?
    Steve Rhoden
    (Cow Leader)
    1-876-832-4956
  • Rick Wise
    March 3, 2013 at 12:10 am
    John, essentially, yes. I’m trying some other high settings as well. Looks good. Thanks guys! (Just back so first time I’ve had a chance to try this out.)
    Rick Wise
    Cinematographer
