Activity Forums Adobe Premiere Pro Another Color Match Problem…
  • Another Color Match Problem…
    Posted by Brent Ingroum on February 16, 2010 at 9:45 pm
    Our church currently records it’s services using three cameras and a switcher. We record from the switcher to a hard drive. I think it is important to know that we use a component output from the switcher into the hard drive.
    Here’s the problem:
    I imported the recorded clip into Premier and did a quick scrub (as usual) to see if there were any anomalies. Here is what I found:
    https://ingroum.com/100109-01.jpg
    https://ingroum.com/100109-02.jpg
    It seems that somewhere, one of the components was lost. I have tried using the color matching tool in Premier but have had no luck. I would appreciate any help that I can get.
    Brent
    Jim Arco replied 16 years, 7 months ago 3 Members · 3 Replies
  • Jon Barrie
    February 16, 2010 at 11:19 pm
    As your signal seems to have lost an entire third of it’s colour spectrum I’d say you’ll be hard pressed to fix it perfectly, but your best approach is with hue.
    – jon barrie
    Jon Barrie
    aJBprods
    http://www.jonbarrie.net
  • Brent Ingroum
    February 17, 2010 at 12:21 am
    Thanks. That’s what I thought, but I figured I would see if anyone had any additional insight.
    Brent
  • Jim Arco
    February 17, 2010 at 12:43 pm
    You can probably fake the missing color channel using one of the channels that IS there.
    Photoshop or After Effects will allow you to do this. There’s a recent thread in the AE Forum where strong red lighting yielded an image that effectively only had a red channel.
    https://forums.creativecow.net/readpost/2/972962
    You might want to take a look for some ideas.
    It won’t be a simple fix and it probably won’t be an exact match, so you’ll need to decide if the footage is worth the time/effort.
    Jim
