Activity Forums Apple Final Cut Pro Legacy Another clip using existing filename?
  • Another clip using existing filename?
    Posted by Aaron Neitz on May 3, 2005 at 5:04 pm
    What’s going on with Final Cut today. I’ve got a locked DV rough cut. I use Media Manager to create an offline project at 10 bit uncompressed. I switch my media drive over to the RAID. When I go to Batch Capture, I get the dialog that clip X is trying to use the same media file name as clip Y…. but I’m going through the bin, there ARE no duplicate filenames – Media Manager has renamed all my clips for comforming.
    Worse, if I select only 1 file to Batch, it still tells me there’s a duplicate filename….. Then I tell it to SKIP that file, and it will digitize without any problems.
    I’ve done this before, and it’s worked flawlessly. am I going mad?
    Aaron Neitz replied 21 years, 4 months ago 1 Member · 0 Replies
  • 0 Replies
