Activity › Forums › VEGAS Pro › Another Capture Question
  • Another Capture Question
    Posted by Dan Sherman on September 19, 2005 at 12:33 am
    A belated thanks to Edward on the VHS capture quesiton.
    And yes, “disable DV device control” was the solution.
    It is now enabled again as I try to capture from DV tape device.
    First thing that is unusual is that the window asking to save from beginning of tape,—current position or not at all doesn’t pop up like it used to.
    Second thing is after adding a new folder and checking it and hitting apply and OK,—all of the shuttle controls are greyed out.
    Can’t seem to figure out what the heck is going on.
    There is a DV Tape in my DV device, a camera, and it is on and in VTR mode.
    Any help would be much appreciated.
    Dan Sherman replied 21 years ago 3 Members · 3 Replies
  • Edward Troxel
    September 19, 2005 at 1:10 am
    [Peabody] “First thing that is unusual is that the window asking to save from beginning of tape,—current position or not at all doesn’t pop up like it used to”
    That should happen each time you change a tape or each time capture loses and regains focus.
    [Peabody] “Second thing is after adding a new folder and checking it and hitting apply and OK,—all of the shuttle controls are greyed out.
    Can’t seem to figure out what the heck is going on.”
    Are you SURE that “Device Control” is turned back on??? Also, a reboot never hurts if you haven’t tried that.
    Edward Troxel
    JETDV Scripts
  • Ted Snow
    September 19, 2005 at 1:26 am
    Also check the menu on your camera…make sure DV in is NOT on.
  • Dan Sherman
    September 19, 2005 at 1:53 am
    Tried all that stuff.
    Finally plugged firewire into different receptical on machine and everything sprang back to life.
    May be a card problem.
    Am capturing again.
    Thanks.
