Activity Forums Apple Final Cut Pro Legacy Another audio question
  • Another audio question
    Posted by Juliett on February 24, 2006 at 1:57 pm
    Hi all!
    I am trying to adjust my audio levels in the Audio Mixer tool. I want to move both A1 & A2 at the same time,(gang them I think is the term) .
    I looked for a button within the audio mixer tool but couldn’t find anything. Does anybody know the answer.
    Julie
    Cheers
    Juliett replied 20 years, 7 months ago 2 Members · 2 Replies
  • Andy Mees
    February 24, 2006 at 2:28 pm
    you can channel 1 and 2 of a clip as a single item only if they are a stereo pair … select the tracks then use Modify > Stereo Pair command (Option-L) to pair them … now adjustments will affect both tracks of the clip simultaneously
    if you don’t want to pair them, or they are multiple independent clips then you can make global adjustments to multiple clips or tracks by using the Modify > Levels command. First select all the clips/tracks you want to adjust then select Modify > Levels (or press Cmd-Option-L) to bring up the Gain Adjust dialog where you can make an absoulte or relative adjustment to all the selected clips.
    good luck
    Andy
  • Juliett
    February 24, 2006 at 5:19 pm
    Hi Andy
    Thanks for that, its a great tip.
    Julie.
