Activity › Forums › Maxon Cinema 4D › Another Alpha Problem
  • Another Alpha Problem
    Posted by John Wahoo on April 21, 2013 at 12:45 pm
    this should be very straight forward.
    I have a a material with different Maps (color, specular, normal, and displacement) and want to add an alpha channel.
    I used the original color map that had an alpha channel as well as a black and white image, but both give me a thin black line on the top of the plane, where the material is applied to (see image attached)
    https://oi37.tinypic.com/14uytl2.jpg
    What am i missing?
    thank you
    Brian Jones replied 13 years, 5 months ago 2 Members · 1 Reply
  • Brian Jones
    April 22, 2013 at 2:59 am
    it usually means there is a white line at the top of your alpha (or it was antialiased) try zooming way in in PS and make sure the very top really is black (and if not make it black)
