Activity Forums Avid Media Composer Another Adrenaline problem.
  • Another Adrenaline problem.
    Posted by Andy Garcia on December 15, 2005 at 2:23 pm
    Does anyone have a clue what (in a small grey box): Exception: PMM_INSUFFIENT_MEDIA, means?
    Any ideas would be helpfull.
    Cheers
    Andy
    ‘If the records nice, then play it twice’.
    Scott Davis replied 20 years, 8 months ago 3 Members · 2 Replies
  • Marianna Montague
    December 15, 2005 at 3:13 pm
    what are you doing when the error occurs? If editing, what is in the sequence?
    I know that if you splice tone to the head of a sequence you get the error: Insufficient Media to make the edit. You can try Overwriting instead of Splicing as Overwriting will successfully edit the tone media into the sequence.
    Not knowing what you are doing… this is the best I can advise.
    Marianna
  • Scott Davis
    December 15, 2005 at 4:27 pm
    I had this very same problem last week. The problem was exactly what Mariana said, the tone. After pulling my hair out for a couple of hours I figured this out and overwrote it and all was fine.
