Activity › Forums › AJA Video Systems › another 7.5 bug?
  • another 7.5 bug?
    Posted by Simon Brewster on February 27, 2010 at 9:38 am
    hi i am having problems viewing pal sd out on a sony from apple color…. the image looks like it is being resized by something…
    and as the aja control panel resets to ntsc even though i set it to pal just wondered if these bugs are connected?
    thanks
    s
    Simon Brewster replied 16 years, 7 months ago 3 Members · 8 Replies
  • 8 Replies
  • Jeremy Garchow
    February 27, 2010 at 3:08 pm
    What card do you have?
  • Arnie Schlissel
    February 27, 2010 at 3:29 pm
    An you’ve checked to see that Color is set to display SD PAL?
    Arnie
    Post production is not an afterthought!
    https://www.arniepix.com/
  • Simon Brewster
    February 28, 2010 at 8:51 am
    hi
    i honestly think it is a color issue
    kona does it usual great job in ae and combustion
    basically i have a qt with none as the codec 30 sec seq from flame in pal 720 x 576 and color seems to mangle it … it looks wrong on the image window on the color screen and just looks worse bigger on the sony
    thanks
  • Jeremy Garchow
    February 28, 2010 at 3:21 pm
    Maybe it’s the codec. As a test try trancoding the file to ProRes or Uncomprsssed 8 bit using compressor. Then send that to Color and see want happens.
  • Simon Brewster
    March 1, 2010 at 11:59 am
    hi
    yeah i tried a few codecs but i think it is some sort of color bug … codecs just changed gamma but not the jaggies.. when its rendered it looks fine but try explaining that to your clients
    s
  • Arnie Schlissel
    March 1, 2010 at 1:30 pm
    Do you have “deinterlace previews” on in the user preferences? If so, turn it off, if not turn it on.
    Arnie
  • Jeremy Garchow
    March 1, 2010 at 3:10 pm
    [simon brewster] “when its rendered it looks fine but try explaining that to your clients”
    “It’s going to look good. I promise!”
    SO you’re saying once it’s graded and rendered out of Color, everything looks good?
  • Simon Brewster
    March 1, 2010 at 9:20 pm
    so i found the problem and its not a bug … which is good
    in color in the setup room change the internal pixel format to anything but floating point and the jaggies go away .. so its a graphics card based issue … but remember when its time to render put it back to floating point
    s
