Activity Forums Apple Final Cut Pro Legacy another 5.1.2 update error
  • another 5.1.2 update error
    Posted by Christian Kinnard on September 29, 2006 at 11:05 pm
    I installed the update and on start up I get the error “Registration Error: An Error occured: coreFoundationUnknownErr.” I then get the start up window and then it quits.
    I tried trashing my FCP System ID and entering my serials again, but got the same message. I also, tried all the pluggins from previous strings but that didn’t help either.
    Reinstall is not a big deal, but before I go though that, am I missing something obvious about the System ID maybe? I checked the permissions everything seemed in order.
    Christian Kinnard replied 19 years, 11 months ago 3 Members · 7 Replies
  • 7 Replies
  • David Roth weiss
    September 29, 2006 at 11:10 pm
    What version are you updating from?
  • Christian Kinnard
    September 29, 2006 at 11:34 pm
    I’m updating from 5.1.1, I did the QT update a week or two ago and it was fine. Also I’m on a
    1.67 Ghz G4 Powerbook
    1.5 Gb RAM
    OS: 10.4.7
    Christian
  • Christian Kinnard
    September 29, 2006 at 11:36 pm
    I’m updating from 5.1.1, I did the QT update a week or two ago and it was fine. When the FCP window flashes up before it quits, FCP says it’s at 5.1.2. Also I’m on a:
    1.5 Gb RAM
    OS: 10.4.7
    Christian
  • David Roth weiss
    September 29, 2006 at 11:43 pm
    Humm? Could be the plugin issue others have mentioned, see the other threads below. I had no problems here, so I can vouch for the soundness of the update.
    DRW
  • Christian Kinnard
    September 29, 2006 at 11:51 pm
    Oh well, thanks for the quick response. Like I said it’s not the end of the world for me to clean it out and go back to 5.1.1. Just always seem to remember something obvious I coulld have done after I’ve already reinstalled.
    Thanks again,
    Christian
  • Keith Koby
    October 1, 2006 at 1:09 pm
    I’ve heard about conflicts with avid drivers and 5.1.2. You wouldn’t happen to have an avid product on the same machine?
  • Christian Kinnard
    October 1, 2006 at 10:24 pm
    Actually I do, xpress DV, maybe I’ll try to uninstall that first. Thanks. I’ll let you know.
    Christian
