Activity Forums Adobe After Effects Another 3D Pre-Comp Issue
  • Another 3D Pre-Comp Issue
    Posted by Aharon Charnov on January 1, 2007 at 5:48 pm
    I brought in a number of photoshop flats into a composition. All of them have been used as 3D elements. The 3D Switches are on all of them. When I then nest this composition into a new composition they come in as a flat. When I switch the nested comp to 3D the flat arranges itself in 3D space but the depth cues from the first comp to not carry over. I’ve done this before only I used after effects solids as stand ins. Then it worked fine but now I lose my 3D-ness in the nested comp. Anyone know why or how to defeat it?
    ACC
    Aharon Charnov replied 19 years, 8 months ago 2 Members · 2 Replies
  • Mylenium
    January 1, 2007 at 7:08 pm
    Are you using continuously rasterize/ collapse transformations properly? If you apply it to your imported bitmap layers it has a different meaning than on vector based layers or solids. Check this, I’m sure somewhere you are using one such switch that screws AE’s rendering order and flattens your folded comp.
    Mylenium
    [Pour Myl
  • Aharon Charnov
    January 4, 2007 at 10:12 am
    Thank you that worked well.
