Activity Forums Adobe After Effects Annoying Problem!
  • Annoying Problem!
    Posted by John Elliott on May 28, 2009 at 11:12 am
    Hi there is probably a really easy solution to this problem and I’m hoping someone can help because its really annoying me now!
    Recently when moving the timeline marker left and right in after effects I don’t get a realtime preview anymore.
    I think I might have pressed a shortcut accidentally?
    Normally, when I moved the timeline marker left and right I got a realtime preview of the frames. This is really annoying me now because I only get a preview when I let go of the marker and I’m finding it really annoying to animate!
    Any help would be greatly appreciated. 🙂
    John Elliott replied 17 years, 4 months ago 2 Members · 2 Replies
  • Joe Laude
    May 28, 2009 at 11:41 am
    Try the different Fast Previews settings in your comp window. It’s a pulldown menu that looks like a little lightning bolt, near the right side of all the icons. See which one works best for you. I find turning them off actually makes things preview faster on some comps.
  • John Elliott
    May 28, 2009 at 11:49 am
    Hey, thanks for you help.
    I actually just stumbled across the problem! I had the “live update button” turned off at the top of the timeline! I knew it was something simple!
