Activity Forums Adobe After Effects annoying problem need help
  • annoying problem need help
    Posted by Spotcharlie on July 27, 2006 at 5:49 pm
    so i have two different macs running after effects. same version same specs on each computer. on one i use AE and when i scale or move stuff around it does it. i see my graphic grow or shrink or move left to right when i drag it. on my other AE setup i scale or move stuff and the graphic doesn’t do anything until i’m done with the adjustment. example, if i have a layer that is simply a red circle. i want to reduce it’s size to 50% i scrub the scale down to 50% and i see the red circle shrink. like i see all the values of the circle shrink. then on my other AE i scrub the scale down and the circle doesn’t shrink. i let go of the scale scrub and the circle is now 50%. this is really annoying and just lame especially when trying to space and size things with relations to others. does anyone know the trick to fix this. i’ve compared all the openGL and ram settings on both machines and they’re the same. this problem even occurs on solid layers. it’s driving me crazy. please help
    Mylenium replied 20 years, 1 month ago 2 Members · 1 Reply
  • Mylenium
    July 28, 2006 at 5:56 am
    Make sure to activate the “Live-Update” button (formerly “Wireframe Interactions”) in the timeline.
    Mylenium
    [Pour Myl
