annoying lines when camera moves in sony vegas
Posted by Tammy Mclameons on February 23, 2011 at 10:12 pmHey,
So I have a question, when I insert a photo, any type of photo into sony vegas, it intermittently dissapears?? Do you know what is happening and would you very nicely help me with it? thank you very much!
TammyMárcio Nascimento replied 15 years, 7 months ago 3 Members · 7 Replies -
Steve Rhoden
February 24, 2011 at 1:08 amWhat do you mean by dissapear? Be more specific.
Steve Rhoden
(Cow Leader)
Film Maker
Filmex Creative Media.
1-876-832-4956 -
Márcio Nascimento
February 24, 2011 at 2:16 am[tammy Mclameons] “Hey,
Tammy”It never heppened here.
Are your shure that you’re inserting to the timeline? did It dessapears from the machine or from vegas Project Window?Márcio Nascimento
– Editor, cinegrafista e fotógrafo – -
Tammy Mclameons
February 24, 2011 at 5:28 pmit dissapeared from the vegas project window, and when I render it it doesnt show up, but it is definetly inserted into the timeline.
Tammy Mclameons
February 24, 2011 at 5:41 pmthe image dissapears from the media player thing but says in the timeline, and when I render it, it doesnt show up in the video
Márcio Nascimento
February 24, 2011 at 7:47 pmAlways a picture in the timeline appears in the Project window, the inverse don´t. You can have a picture in Project Window and don´t use it in the Timeline.
See if the track isn´t Mutted or other track in solo.
Maybe you are using some plugin that makes the image black and are with the FX Bypass turned on… in this case, you will see the playback in vegas but after render the plugin that turn image black will work and you will not see nothing in the rendered clip.
What is the codec you are using to render?
Is the created video a mpeg, avi, mov or wmv… ?Open the video rendered in vegas and see if it appears.
Check the Video Stream if it is Offline.Márcio Nascimento
Tammy Mclameons
February 24, 2011 at 8:05 pmI render in either wmv or avi, I will experiment with rendering settings… hold on Ill get back to you on that one. But the track is not blocked out and I dont think there is any wrong fx on there to make it go black. hmmm
Márcio Nascimento
February 25, 2011 at 4:45 am[tammy Mclameons] “I render in either wmv or avi,”
Try to render in mpeg.
Márcio Nascimento
