Activity › Forums › Apple Final Cut Pro Legacy › Annoying color shift with text overlay
  • Annoying color shift with text overlay
    Posted by Rocco Rocco on May 8, 2011 at 6:35 am
    A doc I just edited came back to me from the colorist as Pro Res 4444. I dropped it into the timeline to add lower thirds, titles and so on.
    I’m using the basic FCP titles. When I add a title and render, there is a noticeable – and unusable – shift in the brightness level. Even if I export a Quicktime, you still see it.
    When my footage was PR422, there was no problem. Now that I’m editing in a PR4444 timeline with PR4444 footage this is happening.
    Is this a common problem that I’ve been lucky to miss or have I F-ed it up somehow? Any ideas? THANKS
    Joseph Owens replied 15 years, 4 months ago 5 Members · 4 Replies
  • Bouke Vahl
    May 8, 2011 at 7:32 am
    So why not transcode to 422 and be done with it?
    If it is already graded, and the source was 422, for what reason would you need 4444?
    Bouke
    https://www.videotoolshed.com/
    smart tools for video pros
  • Chris Tompkins
    May 8, 2011 at 12:29 pm
    Make sure you sequence settings are set to the highest.
    Chris Tompkins
    Video Atlanta LLC
  • John Pale
    May 8, 2011 at 4:25 pm
    Sounds like the ProRes 4444 files are RGB and you are rendering YUV.
  • Joseph Owens
    May 9, 2011 at 6:11 pm
    [Bouke Vahl] “for what reason would you need 4444?”
    The simple answer is that there is a widespread belief that “bigger” is better, whereas “the same” is the correct approach, because there is no gain in using the 4:4:4:4 container, but it does make the anticipated codec decoding ambiguous.
    The shift is pretty much a proxy shift, rendered outside of the normal Y’CbCr/RGB precision rules.
    jPo
    You mean “Old Ben”? Ben Kenobi?
