Annoying bug with premier pro on iMac 21″
Hi, so each time I’m lunching the software theres a small gap between the bottom end of the software and the desktop and I need to drag down the software and stretch it up because the gap takes a little bit from the size of the monitors or if I’m moving between desktops I need to the this process from the beginning.
is there a way to lunch on full screen from the beginning ?
