Activity › Forums › Apple Final Cut Pro Legacy › Annotation edit in FCP
Posted by Audrey Villiard on October 16, 2010 at 7:18 pmHello,
I have done subtitles in Annotation edit. I export these in XML files.
In Final Cut Pro, the sequence created contained clips, the timecode is the good one, but I cannot see the words. It’s all black (even though I have exported the subtitles in white, etc.).
Can someone help me ?Thank you,
Andreas Kiel replied 15 years, 11 months ago 2 Members · 3 Replies -
Andreas Kiel
October 17, 2010 at 2:07 pmHave a look at the XML and check whether it contains text and what the color is.
Andreas
Spherico
https://www.spherico.com/filmtools -
Audrey Villiard
October 17, 2010 at 3:53 pmNo, it doesn’t seem to contain the text.
What should I do when I export the XML from Annotation Edit ?
Here is a part of the XML, for example.Thank you Spherico,
<?xml version=”1.0″ encoding=”UTF-8″ standalone=”yes”?>
<!DOCTYPE xmeml>FALSE
Sous-titres
0TRUE
30TRUE
3000:00:00:00
0
source
DF-1
-1720
480
FALSE
NTSC-601
,noneTRUE
3024
Final Cut Pro
Apple Computer, Inc.
4.0TRUE
FALSE
YUV8BPPSubtitle
TRUE
30TRUE
FALSE
blackFALSE
Subtitle
Subtitle
Text
generator
videopart1
font
Akkuratstyle
1 -
Andreas Kiel
October 17, 2010 at 6:27 pm
