Activity Forums Adobe Photoshop anit-aliased problem with marquee tool
  • anit-aliased problem with marquee tool
    Posted by Brettw on November 19, 2006 at 8:20 pm
    Hello,
    Normally when I use the rectangle marquee tool, I believe anti-aliased is turned on. The marquee tool isn’t functoning like it usually does, and I noticed that anti aliased is turned off. I would like to turn anti-aliased on, to see if that allows the marquee to work like it normally does, however, it won’t even let me click the anit-aliased box in the toolbar/options bar.
    I am not sure if I acidentally clicked something or what, but this is driving me nuts.
    Andrew Kramer replied 19 years, 9 months ago 3 Members · 3 Replies
  • Andrew Kramer
    November 21, 2006 at 11:09 am
    Using the shape tool there are 3 options, vector-filled shape, vector shape, and raster shape. the raster shape is the 3rd option on the right in the top left corner of the options. I think when you have this selected you will be able to turn on aliasing if it isn’t already on.
    Andrew Kramer
  • Richard Harrington
    November 26, 2006 at 11:47 pm
    Rectangular Marquee never has anti-alias (only feather)
    Eliptical marquee has both…
    Check if you have a high feather value insterted by mistake
    Richard M. Harrington, PMP
    Author: Photoshop CS for Nonlinear Editors, Understanding Adobe Photoshop, and ATS:iWork
  • Andrew Kramer
    November 29, 2006 at 10:57 am
    For some reason I was thinking about the shape tool…
